The JG960A is a non-PoE model (link): HPE OfficeConnect 1950 switch with 24 1GbE ports, 2 SFP+ ports, and 2 10GbE ports.
You would need the JG962A equivalent, which has PoE: HPE OfficeConnect 1950 switch with 24 1GbE, power-over-Ethernet-plus ports, 2 SFP+ ports, and 2 10GbE ports.
Original Message:
Sent: Apr 11, 2024 06:05 AM
Subject: HPE 1950-24G-2SFP+-2XGT JG960A POE not working
Greetings Aruba Community,
I'm trying to activate POE on the JG960A, but i was unable to do so, on the GUI i get ports greyed out, on the CLI i get a message says POE is disabled. hope to get an answer. Best regards,
