We need to change the SSL-certificate on the Web UI to a certificate from our internal CA. How can this be achieved? Is there a way to generate a CSR file to send it to our CA to replace the self-signed certificate on the 1950?
Thanks for any advice!
Rgds.Stefan
Looks there is a provision for managing certificates.
you may browse the document here: - https://support.hpe.com/hpsc/doc/public/display?docId=c04657809
I also have the same problem that the WebGUI is using a self-signed certificate and I want to replace it with a trusted one.
The linked User Guide has no information on how to make the WebGUI use a particular certificate.
Did anyone ever find the answer to this?
I have successfully imported a trusted certificate, but the WebGUI service is still using the self-signed certificate, and I don't know how to make it use the new certificate.
