Wired Intelligent Edge
HPE 5130: Client Connection problem
  • 1.  HPE 5130: Client Connection problem
    Posted Jun 19, 2019 04:04 AM
    I know I may not be quite right here because it's about HPE 5130 switches.
    But maybe someone can help me with an idea :)
    We have 5130 switches in the IRF stack.
    They run so far without problems.
    But:
    After booting up the PC, no Internet connection is displayed (yellow exclamation mark) for approx. 30 seconds.
    If the user logs in too fast, it can happen that a drive does not connect.
    Is there a setting in the switches?
    The clients are all on Windows 10.
    Problem persists, even without dhcp configuration.
  • 2.  RE: HPE 5130: Client Connection problem
    Posted Jun 19, 2019 06:44 AM
    Can you share the port configuration?
    Is STP edge port enabled for the ports?
  • 3.  RE: HPE 5130: Client Connection problem
    Posted Jun 19, 2019 07:51 AM
    thanks for the reply.
    It is a flat config only vlan 1 (dont kill me for this, it is not final :) )
    version 7.1.070, Release 3208P15
    sysname Switch53
    clock timezone Amsterdam add 01:00:00
    clock summer-time FDT 02:00:00 March last Sunday 03:00:00 October last Sunday 01:00:00
    clock protocol ntp
    irf mac-address persistent timer
    irf auto-update enable
    undo irf link-delay
    irf member 1 priority 10
    irf member 2 priority 1
    lldp global enable
    password-recovery enable
    vlan 1
    irf-port 1/2
    port group interface Ten-GigabitEthernet1/0/28
    irf-port 2/1
    port group interface Ten-GigabitEthernet2/0/28
    stp global enable
    interface NULL0
    interface Vlan-interface1
    ip address 172.16.1.53 255.255.0.0
    interface GigabitEthernet1/0/1
    port link-type trunk
    port trunk permit vlan1
    interface GigabitEthernet1/0/2
    port link-type access
    port access permit vlan 1
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
    interface GigabitEthernet1/0/21
    interface GigabitEthernet1/0/22
    interface GigabitEthernet1/0/23
    interface GigabitEthernet1/0/24
    interface GigabitEthernet2/0/1
    interface GigabitEthernet2/0/2
    interface GigabitEthernet2/0/3
    interface GigabitEthernet2/0/4
    interface GigabitEthernet2/0/5
    interface GigabitEthernet2/0/6
    interface GigabitEthernet2/0/7
    interface GigabitEthernet2/0/8
    interface GigabitEthernet2/0/9
    interface GigabitEthernet2/0/10
    interface GigabitEthernet2/0/11
    interface GigabitEthernet2/0/12
    interface GigabitEthernet2/0/13
    interface GigabitEthernet2/0/14
    interface GigabitEthernet2/0/15
    interface GigabitEthernet2/0/16
    interface GigabitEthernet2/0/17
    interface GigabitEthernet2/0/18
    interface GigabitEthernet2/0/19
    interface GigabitEthernet2/0/20
    interface GigabitEthernet2/0/21
    interface GigabitEthernet2/0/22
    interface GigabitEthernet2/0/23
    interface GigabitEthernet2/0/24
    interface Ten-GigabitEthernet1/0/25
    interface Ten-GigabitEthernet1/0/26
    interface Ten-GigabitEthernet1/0/27
    interface Ten-GigabitEthernet2/0/25
    interface Ten-GigabitEthernet2/0/26
    interface Ten-GigabitEthernet2/0/27
    sntp enable
    sntp unicast-server 172.16.0.16
  • 4.  RE: HPE 5130: Client Connection problem
    Posted Jun 19, 2019 10:13 AM
    Configure the following command at the interfaces where the clients are connected to.
    stp edged-port
  • 5.  RE: HPE 5130: Client Connection problem
    Posted Jun 28, 2019 02:25 AM
    Hello, I set the setting accordingly.
    The first tests were positive, but Windows still shows the yellow exclamation mark on the network connection.
    But I will observe that.
    Are there any other settings ?
    for example regarding learning mac addresses ?
    Can this also be related ?
    I just ask :)
    Thanks a lot first of all.
  • 6.  RE: HPE 5130: Client Connection problem
    Posted Jun 28, 2019 08:06 AM
    This can be different issues.
    first check if the MAC address at the switch is learned fast enough.
    This can also be some DHCP issues.
