Hello
The printer is on interface GigabitEthernet1/0/19
The trunk with the Cisco in on interface Ten-GigabitEthernet1/0/25
I replaced the printer with a computer (same ip : x.x.x.19)
I have realy a strange arp behavior
Computer x.x.x.19 is on GigabitEthernet1/0/19
Print server has x.x.x.23 ip
The ping command from x.x.x.23 (print server) to x.x.x.19 is unreacheable
I can't see the x.x.x.19 mac address in the arp cache
I initialise a ping from x.x.x.19 to x.x.x23, after a while it responds
At the same time, the ping -t from x.x.x.23 to x.x.x.19 changes from unreacheable to a correct response
From x.x.x.23, If i clear the arp cache (arp -d). The ping doesn't respond anymore
It sounds like an arp problem
If i replace the 5130 witch a Cisco 2950 I have no problem
With the 5130, the ping from any other VLAN works fine
I don't have any information regarding the print server or the printer.
I only have the information from the vlan 1
version 7.1.045, Release 3115P07
sysname L2-INFO-04
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
port-security enable
password-recovery enable
vlan 1
vlan 208
vlan 450
vlan 751
vlan 755 to 756
vlan 759
vlan 765
vlan 769
vlan 777
vlan 779
vlan 888
vlan 922
interface NULL0
interface Vlan-interface1
ip address 192.168.1.4 255.255.255.0
interface Vlan-interface450
description Management
ip address 172.16.22.4 255.255.252.0
description 758 / D19 / Switch imprimantes
port access vlan 759
port-security intrusion-mode blockmac
port-security max-mac-count 3
port-security port-mode autolearn
port-security mac-address security sticky 0015-c5bf-12d4 vlan 759
port-security mac-address security sticky 001b-a944-18ef vlan 759
description Trunk
port link-type trunk
port trunk permit vlan all
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 0
line vty 0 15
authentication-mode scheme
protocol inbound ssh
idle-timeout 0 0
line vty 16 63
ip route-static 0.0.0.0 0 192.168.1.250
snmp-agent
snmp-agent local-engineid 800063A280D8940325CF5B00000001
snmp-agent sys-info version all
ssh server enable
radius scheme system
user-name-format without-domain
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
