Network Management
HPE 5130 switches unable to add into AirWave NMS server
  • 1.  HPE 5130 switches unable to add into AirWave NMS server
    Posted Jul 13, 2018 02:48 AM
    As per the below post, the HP 5130 with version 7.0 onwards will add into Aruba AirWave NMS but not able to add and showing SNMP get failed error in AirWave.
    I am trying to add with SNMPV3, I have tried HPE office connect and Universal device but no luck.
    Can anyone provide the solution please....
    Switch Model: 5130-24G-4SFP+ EI JG932A
    VENDOR_NAME          : HPE
    Version 7.1 running
    Thanks and regards,
    Ashok
  • 2.  RE: HPE 5130 switches unable to add into AirWave NMS server
    Posted Jul 13, 2018 09:57 AM
    When adding a device for SNMPv3, you need to update the Group -> select group -> Basic tab to use SNMPv3 for that device series type.  Otherwise it will try to use the default SNMPv2.
  • 3.  RE: HPE 5130 switches unable to add into AirWave NMS server
    Posted Jul 22, 2018 03:17 AM
    Thank you for your reply.
    Have got a solutioin for my issue.
    Added the HP switch as a Universal device in AirWave, changed the SNMPV3 in the group and the below is the configuraion from swith end.
    snmp-agent
    snmp-agent sys-info version v3
    snmp-agent group v3 XXXX authentication write-view XXXX
    snmp-agent usm-user v3 XXXX XXXX simple authentication-mode sha <password> privacy-mode aes128 <password>
    Thanks and regards,
    Ashok
