Comware
HPE 5500 - IRF
  • 1.  HPE 5500 - IRF
    Posted Jul 21, 2022 11:04 AM
    French Version :
    Bonjour,
    J'ai un stack de 5 HPE 5500 EI, connecté ensemble comme ci-dessous :
    SW  -  IRF-Port1                            ->  SW  - IRF-Port2
    1 - Ten-GigabitEthernet 1/1/1    ->     2  - Ten-GigabitEthernet 2/1/2
    2 - Ten-GigabitEthernet 2/1/1    ->     3  - Ten-GigabitEthernet 3/1/2
    3 - Ten-GigabitEthernet 3/0/30  ->     4 - Ten-GigabitEthernet 4/0/30
    4 - Ten-GigabitEthernet 4/1/1    ->     5 - Ten-GigabitEthernet 5/1/2
    5 - Ten-GigabitEthernet 5/0/29 ->      1 - Ten-GigabitEthernet 1/0/54
    Je rencontre un souci, car lorsque je déconnecte un lien, l'ensemble du stack ne fonctionne plus.
    Comment, puis-je faire, s'il vous plait, pour que si un lien ne fonctionne plus, maintenir la résilience des liens entre chaque éaquipement ? (sachant que chaque Switch et connecté à 2 autres switches, donc 2 routes possibles).
    En vous remerciant,
    Cordialement
    English Version :
    Hello
    I have a stack of 5 HPE 5500 EI, connected together as below:
    I'm having a problem, because when I disconnect a link, the entire stack doesn't work anymore.
    How can I please ensure that if a link no longer works, maintain the resilience of the links between each team? (knowing that each Switch is connected to 2 other switches, so 2 possible routes).
    Thanking you,
  • 2.  RE: HPE 5500 - IRF
    Posted Aug 03, 2022 03:00 AM
    un petit up
  • 3.  RE: HPE 5500 - IRF
    Posted Aug 11, 2022 10:10 PM
    3comstack
    Switch1:
    Sys
    Sysname hello                                                ::: not: stack olacak her cihazın sistem adı aynı olmalı.
    fabric-port gigabitethernet 1/0/25enable       ::: gigabit 25 portu stack port olarak etkinleştirilir.
    fabric-port gigabitethernet 1/0/26 enable      ::: gigabit 26 portu stack port olarak etkinleştirilir.
    undo xrn-fabric authentication-mode             ::: stack arası kimlik doğrulamayı kaldırma
    change self-unit to 1                                      ::: bağlı olan ünitenin sırası 1 olarak ayarlanır.
    set unit 1 name Unit1                                     ::: 1 numaralı ünitenin adı Unit1 olarak ayarlanır.
    Switch2:
    Sys
    change self-unit to 2                                      ::: bağlı olan ünitenin sırası 2 olarak ayarlanır.
    set unit 2 name Unit2                                     ::: 2 numaralı ünitenin adı Unit2 olarak ayarlanır.
    Switch3:
    Sys
    change self-unit to 3                                      ::: bağlı olan ünitenin sırası 3 olarak ayarlanır.
    set unit 3 name Unit3                                     ::: 3 numaralı ünitenin adı Unit3 olarak ayarlanır.
    Stack kabloları görseldeki gibi bağlanır ve stack modu etkinleşmiş olur.
