Comware
HPE 5700 Bridge Aggregation 10G and 40G Ports
  • 1.  HPE 5700 Bridge Aggregation 10G and 40G Ports
    Posted Sep 21, 2017 01:25 PM
    We have 2 5700 FF switches that currently have a port link-aggregation setup across 4 of the 10G ports and is working fine as  a 40G channel. We recently purchased 40G SFP+ modules that I would like to now use to replace that communication channel.
    Initially, my thought is to add the 40G ports into the LAGG group with the 10G modules and then once everything is working, remove the 10G as needed. However, when I add my first 40G port in, I see no change and when I inspect the port, I see that it shows the following status:
    Current state: UP
    Line protocol state: DOWN(LAGG)
    I can see that the port is up, but for some reason the line protocol doesn't come up. Is it possible that you are not able to do LAGG across the SFP+ and the QSFP+ ports?
    If so, is there a way to bring up a separate LAGG group for just the QSFP+ ports without causing a network disruption? I started that route yesterday but quickly shut it down when I started noticing some indicators that made me think there may have been a routing issue starting.
    Configurations:
    interface Bridge-Aggregation40
     description 5700Cross
     port link-type trunk
     port trunk permit vlan all
     link-aggregation mode dynamic
    interface Ten-GigabitEthernet1/0/40
     port link-aggregation group 40
    interface FortyGigE1/0/41
    #FlexFabric
    #Bridge-Aggregation
    #LAGG
    #5700
    #Link-Aggregation
  • 2.  RE: HPE 5700 Bridge Aggregation 10G and 40G Ports
    Posted Sep 21, 2017 05:00 PM
    What you're primarily trying to achieve (adding a FortyGE port as an additional member of an existing LAG which already has one or more TenGE member ports) is not possible because LAG admits only member ports with same attributes (read: all physical ports in the same Link Aggregation Group must have the same Speed, Duplex Mode and Flow Control settings).
