Wired Intelligent Edge
HPE 5700 routing features
  • 1.  HPE 5700 routing features
    Posted Nov 11, 2019 05:22 AM
    Hi can someone explain does HPE 5700 support OSPF, BGP routing and how many routes it  support's, because datasheet tells that there is only RIPv2 and static routing support, but configuration guide also defines how to configure OSPF, BGP, IS-IS, RIP, Static routing, but do not mention how many route can be contain in the routing table
  • 2.  RE: HPE 5700 routing features
    Posted Nov 11, 2019 08:11 AM
    The 5700 is limited with 1000 ARP entries, and a routing table limit of 128 routes.
    I never configured the 5700 for ospf/bgp so im not sure if it is capable, i just use it as a layer 2 switch, or in small enviroment with basic routing.
  • 3.  RE: HPE 5700 routing features
    Posted Nov 11, 2019 08:36 AM
    But HPE 5700 switches L3 IP routing guide explain how to configurate BGP, OSPF, IS-IS and so on, so is this true or not, maybe someone have tried this?
  • 4.  RE: HPE 5700 routing features
    MVP GURU
    Posted Nov 11, 2019 05:12 PM
    5700 or 5710 ?
  • 5.  RE: HPE 5700 routing features
    Posted Nov 12, 2019 03:11 AM
    5700
  • 6.  RE: HPE 5700 routing features
    MVP GURU
    Posted Nov 12, 2019 03:38 AM
    @Audrius wrote:
    5700
    there is some feature but it is not really recommanded to use for router (limited ARP entries...)
  • 7.  RE: HPE 5700 routing features
    Posted Nov 12, 2019 06:02 AM
    So OSPFv2 is supported or not? And how many OSPFv2 routes, this is the main question.
  • 8.  RE: HPE 5700 routing features
    MVP GURU
    Posted Nov 12, 2019 10:10 AM
    No from Datasheet
    it is a L3 "Light" with only static and RIP
