Wired Intelligent Edge
HPE 5930 40G QSFP+ TO 4 10G DAC CONNECTIONS TO AURBA 72XX CONTROLLER - CONNECTIVITY VERIFIED
  • 1.  HPE 5930 40G QSFP+ TO 4 10G DAC CONNECTIONS TO AURBA 72XX CONTROLLER - CONNECTIVITY VERIFIED
    Posted Jun 08, 2016 02:40 PM
    VERIFICATION LAB CONNECTIVITY
    PARTS
    JG726A – FF 5930-32QSFP+
    JG330A – X240 QSFP+ TO 10G SFP+ DAC 3M SPLITTER CABLE
    7210-US – ARUBA 7210-US MOBILITY CONTROLLER
    HPE 5930 40 GIGABIT TO 10 GIGABIT SETUP
    1. ENSURE THAT THE 5930 FOURTY GIGABIT INTERFACES CAN BE BROKE OUT INTO MULTIPLE 10 GIGABIT INTERFACES **
    2. THIS COMMAND SEQUENCE CHANGES THE 40 GIGABIT INTERFACE TO SUPPORT 4 10 GIGABIT INTERFACES
      1. interface FortyGigE 1/0/28
      2. using tengige
    3. TO ACCESS THE NEW 10 GIGABIT INTERFACE
      1. interface Ten-GigabitEthernet 1/0/28:1-4 (CABLE LABEL A-D)
    ARUBA 7210 SETUP
    1. PLUG AND PLAY
    VERIFICATION OF CONNECTIVITY (HPE 5930)
    [DC1-5930-2]display interface Ten-GigabitEthernet 1/0/28:1 brief
    Brief information on interfaces in bridge mode:
    Link: ADM - administratively down; Stby - standby
    Speed: (a) - auto
    Duplex: (a)/A - auto; H - half; F - full
    Type: A - access; T - trunk; H - hybrid
    Interface            Link Speed   Duplex Type PVID Description
    XGE1/0/28:1          UP   10G(a)  F(a)   A    1
    [DC1-5930-2]display interface Ten-GigabitEthernet 1/0/28:2 brief
    Speed: (a) - auto
    XGE1/0/28:2          UP   10G(a)  F(a)   A    1
    [DC1-5930-2]display interface Ten-GigabitEthernet 1/0/28:3 brief
    Speed: (a) - auto
    XGE1/0/28:3          DOWN auto    A      A    1
    DC1-5930-2]display interface Ten-GigabitEthernet 1/0/28:4 brief
    Speed: (a) - auto
    XGE1/0/28:4          DOWN auto    A      A    1
    VERIFICATION OF CONNECTIVITY (ARUBA 7210)
    (Aruba7210-Master-01) #show interface gigabitethernet 0/0/2
    GE 0/0/2 is up, line protocol is up
    Hardware is 10 Gigabit Ethernet, address is 00:1A:1E:02:3B:CB (bia 00:1A:1E:02:3B:CB)
    Description: GE0/0/2 (Fiber Connector)
    Encapsulation ARPA, loopback not set
    speed (10 Gbps)
    MTU 1500 bytes, BW is 10000 Mbit
    Last clearing of "show interface" counters 182 day 22 hr 48 min 23 sec
    link status last changed 0 day 0 hr 24 min 41 sec
        61 packets input, 20442 bytes
        Received 61 broadcasts, 0 runts, 0 giants, 0 throttles
        0 input error bytes, 0 CRC, 0 frame
        61 multicast, 0 unicast
        5473 packets output, 483967 bytes
        0 output errors bytes, 0 deferred
        0 collisions, 0 late collisions, 0 throttles
    This port is TRUSTED
    (Aruba7210-Master-02) #show interface gigabitethernet 0/0/2
    Hardware is 10 Gigabit Ethernet, address is 00:1A:1E:02:3A:3B (bia 00:1A:1E:02:3A:3B)
    speed (10 Gbps)
    Last clearing of "show interface" counters 182 day 22 hr 49 min 57 sec
    link status last changed 0 day 0 hr 26 min 11 sec
        67 packets input, 21861 bytes
        Received 67 broadcasts, 0 runts, 0 giants, 0 throttles
        67 multicast, 0 unicast
        2863 packets output, 183232 bytes
    ** The HPE 5930-32QSFP+ supports 40GbE to 4x10GbE fan out cables in 24 of the 32 QSFP+ ports (ports 5-28).
    The 5930-2Slot switch supports splitting all of the fixed 40GbE ports and the modular 40GbE ports into 4x10GbE ports using fan-out cables.
    The 5930-4Slot switch supports splitting 40GbE ports into 4x10GbE ports using fan out cables noting the following restrictions:
    • The 2x40GbE ports on the 24 port SFP+/2 port QSFP+ modules (JH180A, JH181A, JH184A, JH182A) cannot be split into 4x10GbE ports
    • The last two 40GbE ports (ports 7&8) on the 8 port QSFP+ module (JH183A) cannot be split into 4x10GbE ports
  • 2.  RE: HPE 5930 40G QSFP+ TO 4 10G DAC CONNECTIONS TO AURBA 72XX CONTROLLER - CONNECTIVITY VERIFIED
    Posted Jan 11, 2017 12:26 PM
    Have a similar case: 72xx (DAC SFP+) ==(LAG)==> 5900AF (SFP+)
    Thanks for the INFO.
