Comware
  • 1.  HPE 5945 - new first login console
    Posted Nov 10, 2020 06:20 AM
    I have installed a new switch 5945 and i want login for the very first time through console. I press the CTRL-D or CTRL-C to break the autoconfig. Which i normally on others models like 5510.
    After i break the autoconfig, i see login prompt via the console. I have tried username: admin with no password, but that failed.
    Is there another default login details with console connection?
    Thanks in advance.
    regards,
    ManYau
    #Console
    #HPE5945
  • 2.  RE: HPE 5945 - new first login console
    Posted Nov 10, 2020 11:42 AM
    Hi @manyaulee !
    Seems like somebody was playing with the configuration of this switch and locked the console access with username/password. You need to boot to the Extended Boot Menu and choose "Skip current system configuration" then reboot. On the next boot the switch will start with empty configuration and console will be unlocked. Do not forget to run "save safely force" as soon as you log into the switch to write the default config as "saved-configuration".
  • 3.  RE: HPE 5945 - new first login console
    Posted Nov 11, 2020 10:15 AM
    Hi Ivan,
    Thanks for your reply.
    I was afraid of that, i will give it a try and will let you know how it goes.
    regards
  • 4.  RE: HPE 5945 - new first login console
    Posted Nov 11, 2020 11:33 AM
    I did what you suggest it, but that didn't work. so i have choose " Change authentication for console login" in the extend boot menu. After reboot i was able to login the switch with console.
    EXTENDED BOOT MENU
    1. Download image to flash
    2. Select image to boot
    3. Display all files in flash
    4. Delete file from flash
    5. Restore to factory default configuration
    6. Enter BootRom upgrade menu
    7. Skip current system configuration
    8. Set switch startup mode
    9. Set default boot storage medium
    0. Reboot
    Ctrl+F: Format file system
    Ctrl+P: Change authentication for console login
    Ctrl+R: Download image to SDRAM and run
    Ctrl+C: Display Copyright
    regards,
