Hi people,
i'm working on some HPE 5945 with Comware 7.1.070 where I should login via RADIUS, where the server is a FortiAuthenticator.
Here is part of my configuration:
line class aux
authentication-mode scheme
user-role network-admin
line class vty
user-role network-operator
line aux 0 1
line vty 0 63
protocol inbound ssh
idle-timeout 30 5
ssh server enable
ssh user admin service-type stelnet authentication-type password
password-control enable
undo password-control aging enable
undo password-control length enable
undo password-control composition enable
undo password-control history enable
password-control login-attempt 3 exceed unlock
password-control update-interval 0
password-control login idle-time 0
radius enable
radius scheme fortiauth
primary authentication <IP_FORTIAUTH>
primary accounting <IP_FORTIAUTH>
key authentication cipher <sharedkey>
key accounting cipher <sharedkey>
user-name-format without-domain
domain fortiauth
authentication login radius-scheme fortiauth local
authorization login radius-scheme fortiauth local
accounting login radius-scheme fortiauth local
domain system
domain default enable fortiauth
role default-role enable
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
service-type telnet ssh terminal
authorization-attribute user-role network-admin
authorization-attribute user-role network-operator
local-user <localuser2> class manage
return
When I login i receive this output:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/bd28def6a5c649fea8c0b83a3aec2a71.jpg)
Taking a look into FortiAuthenticator I see that the login is successful:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/e2f6a0ecdeb0456abe7fb82e41b6dccb.jpg)
There's an error into my configuration?
Should i pass particular attributes from Radius server?
Stefano
