Comware
  • 1.  HPE 6127XLG - bpdu-drop doesn't seem to work
    Posted Jul 26, 2024 10:03 AM
    I am replacing a 6120 blade switch with 6127XLG. With the 6120 I had bpdu filter configured for an uplink port so it drops bpdus sent on the uplink interface connected to a switch which has a bpduguard enabled. However, the 6127 does not have a bpdu filter option but instead it has bpdu drop, which I am assuming should do the same thing. In fact, it seems to keep forwading the bpdus up the port connected to the switch with the bpduguard enabled, since the port immediately transitions to Error Disabled. I ended up disabling the STP on the port to workaround this.
    Anyone knows why it's not working and what else I can do with keeping stp enabled?
  • 2.  RE: HPE 6127XLG - bpdu-drop doesn't seem to work
    Posted Aug 06, 2024 08:49 AM
    Is this community thing working? Not even views. How do we get support for these issues if no one is even looking at this?
  • 3.  RE: HPE 6127XLG - bpdu-drop doesn't seem to work
    Posted Aug 07, 2024 03:42 AM
    Hi Gedit
    (Community members "do what they can", and sometimes they are not as reactive as a pro support team)
    Anyway, 6127 is "HPE ProVision-based switches (formerly E-Series/ProCurve)", not comware ?
    Why don't you just enable and configure spanning tree on both switches instead of trying to drop BPDUs ?
    BPDU-drop works on "incoming" bpdus, not egress. Extract from doc : "A BPDU drop-enabled port does not receive any BPDUs "
    The same for "bpdu-protection" function.
    Maybe you are looking for "tc-restriction" function...
    Frederic
    (kudos welcome)
  • 4.  RE: HPE 6127XLG - bpdu-drop doesn't seem to work
    Posted Aug 07, 2024 09:55 AM
    HI Frederic,
    Thank you for your response. I did originally post this on the HPE community and was advised that the support for this switch has moved to this community.
    I must say that documentation is a bit cryptic, since this type of switch is an edge that connects to ToR or other switch/router. So my understanding of this feature, that if the switch received BPDUs on the port it will drop them, OK so I guess if it receives them from the network going "downstream" to the end host connected to the switch, it will drop them? But a end host by definition doesn't receive or send BPDUs. On the port connected upstream (on which I've enabled BPDU drop), if it only drops BPDUs when received, why is it OK to send BPDUs to the upstream switch from which if received will drop them? In other words, this feature is really useless IMO.
    To your question, both switches are configured for Spanning tree, however the upstream switch (which is a customer switch hence not in my control), is configured to not received BPDUs because the customer doesn't want this port to be impacted by STP calculation and having to shut down the port hence decided to disable STP on that port altogether..
    Reading about tc-restriction, I will try it, but this sounds like what bpdu-drop should have done. If the port receives BPDUs it doesn't forward it to other ports, which sounds to me like " bpdu-drop".
    Cheers!
    Gedit
  • 5.  RE: HPE 6127XLG - bpdu-drop doesn't seem to work
    Posted Aug 08, 2024 03:54 AM
    Hi Gedit,
    You don't exactly get the purpose of bpdu management :
    everything is designed to improve stability, and specifically prevent loops. STP is a network wide concept, that relies on all switches in the lan.
    sending BPDUs is different from receiving and processing them. The first send "this is what I know concerning the path to the root switch", while the second collects knowledge from other switches (to check if there is a better root or better path to the root). All this to adapt the forwarding decisions.
    Dropping BPDUs is done by the switch to avoid "poisonous" or unwanted STP traffic inbound, if any, when you (not the switch) know that there will be no loop behind the port. It has nothing to do with the switch sending BPDUs, which is a normal behavior in stp.
    Thus even if it drops incoming BPDUs, it will send it's own (as an active member in the global loop protection process). The only way not to send them is by disabling stp on the port.
    Keep in mind that a switch does not forward received BPDUs (it's a link local transmission) : it receives them, processes them (and never forward them), and if needed generates and send it's own (sometimes with the same informations, sometimes with modified values).
    Having 2 switches set for stp but blocking BPDUs will generate 2 spanning tree domains, which may induce unexpected behaviors.
    If you are sure that no loop will occur, just disable STP on the interconnect ports.
    If you want to keep some kind of loop control, try "loopback-detection" feature (this sends frames that are not BPDUs, thus not affected by bpdu-drops)...
    Frederic
    (kudos welcome)
