Which core swich has configurable routing with HPE and Aruba Portfolio?
What do you need ? (Type of Port / Speed / Modular ?)
Need a layer 3 fixed 24 port swtich with 10 gbe
@alagoutte wrote:What do you need ? (Type of Port / Speed / Modular ?
24 Ports Gbe ? (SFP or Copper ?)
SFP
Greetings!
Just for clarification: what sort of L3 routing protocol support are you looking for, and when you say 10GbE, do you mean all ports are 10G, or just 10G uplinks?
All ports are 10G
You can use 3810m 16sfp+ (with 2 slot with 4 SFP+) or 5400R with line card using SFP+ (like Aruba 8-port 1G/10GbE SFP+)
With 3810, it is possible to have stack and with 5400zl, there is possible to have multiple management module and also use VSF
Hello Alagoutte,
Thank you for your suggestion.
Do the below switches qualify as core swtiches for an fast growing smb with 300 employees?
Yes !
