We have the following switches:
1x Aruba 3810M-16P (JL075A)
1x Aruba 3810M-48P (JL072A)
4x Aruba 2930F (JL254A)
The JL075A and JL072A have a separate SFP + module (JL083A) 4x10 Gpbs
I would like to connect the switches via SFP + together.
The JL075A to JL072A via the SFP + module
The JL254A on the JL075A via the SFP + port
I want to use at least two ports per switch to realize the uplink.
All servers are connected to the Fiber Switch JL075A via AOC cables
The JL072A works as a core switch
We have 6 vlans. It is intended that these can co-exist with each other except the guests subnet VLAN30
My question is:
Should i use port trunking or LACP?
For example:
trunk 45-46 LACP?
or
trunk 45-46 trunk?
Or better advice so that I can make maximum use of the bandwidth.
Thanks.
Rene
#trunking#LACP#sfp+
