HPE Aruba AP-315
  • 1.  HPE Aruba AP-315
    Posted Apr 23, 2019 12:54 PM
    HI guys,
    I need some help.
    I recently purchased a few HPE Aruba AP-315 and I'm having trouble getting started.
    I can't access them to start up the config. I can see their IP on the network along with the MAC address but can't reach the web interface.
    I tried different PoE switches with no result.
    Power light is green and flashing
    Am I doing something wrong?
  • 2.  RE: HPE Aruba AP-315
    Posted Apr 23, 2019 01:24 PM
    On the back does it say 'AP-315' or 'IAP-315'? if it's an AP-315, it will require an Aruba controller to terminate on before it's manageable. if it's 'IAP-315', make sure there's not another IAP cluster or AP on the same VLAN.
  • 3.  RE: HPE Aruba AP-315
    Posted Apr 23, 2019 03:46 PM
    yes it's AP-315.
    I'll have to send them back and get the IAPs
