Comware
HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
  • 1.  HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 04:59 AM
    Hi Team,
                  We have inserted the following two HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A slot  in 6802 Router but showing unknown status for those slot. Could you suggest on this..
    [HPE]display device verbose
    Slot No. Board type Status Primary SubSlots
    0 RT-RSE-X3 Normal Master 0
    1 N/A Absent N/A N/A
    2 Unknown Wait N/A N/A
    3 Unknown Wait N/A N/A
    [HPE]display device manuinfo
    Chassis self:
    DEVICE_NAME:HPE HSR6802 Router Chassis JG361B
    DEVICE_SERIAL_NUMBER:CN03GY3008
    MAC_ADDRESS:NONE
    MANUFACTURING_DATE:2020-03-14
    VENDOR_NAME:HPE
    Slot 0 CPU 0:
    DEVICE_NAME:HPE HSR6800 RSE-X3 Router MPU JH075A
    DEVICE_SERIAL_NUMBER:CN07GXY008
    MAC_ADDRESS:4CAE-A386-B9E0
    MANUFACTURING_DATE:2020-07-18
    VENDOR_NAME:HPE
    Slot 2 CPU 0:
    DEVICE_NAME:HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A
    DEVICE_SERIAL_NUMBER:CN08KXH00X
    MAC_ADDRESS:4CAE-A38A-1658
    MANUFACTURING_DATE:2020-08-20
    VENDOR_NAME:HPE
    Slot 3 CPU 0:
    DEVICE_SERIAL_NUMBER:CN08KXH006
    MAC_ADDRESS:4CAE-A38A-14D8
    VENDOR_NAME:HPE
    Fan 1:
    DEVICE_NAME:HP HSR6802 Router Spare Fan Assembly JG367A
    DEVICE_SERIAL_NUMBER:210212A03WX20300000C
    MAC_ADDRESS:NONE
    VENDOR_NAME:HPE
    [HPE]display version
    HPE Comware Software, Version 7.1.064, Release 7612
    Copyright (c) 2010-2017 Hewlett Packard Enterprise Development LP
    HPE HSR6802 uptime is 0 weeks, 0 days, 0 hours, 2 minutes
    Last reboot reason : User reboot
    Boot image: cfa0:/HSR6800-CMW710-BOOT-R7612.bin
    Boot image version: 7.1.064, Release 7612
    Compiled Aug 24 2017 16:00:00
    System image: cfa0:/HSR6800-CMW710-SYSTEM-R7612.bin
    System image version: 7.1.064, Release 7612
    Slot 0: RT-RSE-X3 uptime is 0 week, 0 day, 0 hour, 2 minutes
    CPU type: FREESCALE P2020 1000MHz
    4096M bytes DDR3 SDRAM Memory
    8M bytes Flash Memory
    128K bytes NVRAM
    PCB Version: Ver.B
    Basic Logic Version: 3.0
    Extend Logic Version: 2.0
    Basic BootWare Version: 2.07
    Extend BootWare Version: 2.07
    [FIXED PORTS] Console (Hardware)Ver.B, (Driver)1.0, (Cpld)2.0
    [FIXED PORTS] AUX (Hardware)Ver.B, (Driver)1.0, (Cpld)2.0
    [FIXED PORTS] MGE (Hardware)Ver.B, (Driver)1.0, (Cpld)2.0
    Regards
    Muthukumar
  • 2.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 05:13 AM
    Hi @Muthukumar1 !
    For how long do they stay in this "Unknown" state? I see the uptime is 2 minutes only. Did you give them enough time to boot?
  • 3.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 05:20 AM
    Hi team,
                  This is new implementation and yesterday only powered on the devices but still slot is unknow status so once again reboot the chassis. These logs captured immediately after rebooting so that showing 2min uptime.
  • 4.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 08:26 AM
    FIP-380 is mentioned for the first time in release notes of HSR6800_7.10.R7809P19 release. I suggest you to upgrade your router to that version - https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=28160&ProductNumber=JH075A&lang=&cc=&prodSeriesId=&SaidNumber=
  • 5.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 10:29 AM
    Hi team,
    OK Thanks and Can we go for following version..
    HSR6800_7.10.R7809P20
  • 6.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Oct 29, 2020 12:51 PM
    Logically thinking, yes. Did I test it? No. But I would definitely try the P20, if it doesn't work, then try P19.
  • 7.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Nov 02, 2020 12:46 AM
    HI Team, We have upgraded the the following firmware version HSR6800_7.10.R7809P20 , now all the slots are working. Thanks team for your suggestion and follow up.
  • 8.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Dec 15, 2020 11:40 AM
    Hi Team
    I have same issue here, im inserted JM050A into HSR 6804,
    the LED is off and status is unknown
    already update to P20 but the result still same
    can you guys help me ? thanks
  • 9.  RE: HPE HSR6800 FIP-380 Flex Int Pltfrm Mod JM050A is unknown status
    Posted Jan 13, 2021 02:49 AM
    Hi @dittoyuda !
    Could you post the output from following commands while the module is plugged in:
    display version
    display alarm
    Also, mention the slot your FIP-380 resides in.
    BTW, it will be good to check logbuffer in your router using "display logbuffer" command for any errors related to the slot where the FIP-380 is plugged in or the FIP-380 module itself. Did you check it?
    Thank you!
