Thank you for your advice, Justin!
I discovered its root cause. I undeployed WSM without sudo command and it could not remove 3 processes: "imcwipsdm", "imcwlandm", "imcwlanperfdm". Therefore, I had to run dma.sh with root privilege, deploy & undeploy WSM, problem is solved.
