Network Management
  • 1.  HPE IMC: Aruba CX, save running to startup option does not work
    Posted Dec 08, 2023 03:26 AM
    Edited by r.grossmann Dec 08, 2023 04:03 AM
    I want to backup the running config to the startup config before deployment, but it does not work, it fails. So the complete task stop and finish unsuccessfull.
    SNMPv3 with access-level rw is configured:
    snmp-server vrf default
    snmp-server trap-source interface vlan8 vrf default
    snmp-server response-source interface vlan8 vrf default
    snmp-server vrf mgmt
    snmp-server system-description LAN-Switch 24P-CX-6200F
    snmp-server system-location *
    snmp-server system-contact *
    snmp-server snmpv3-only
    snmpv3 user * auth sha auth-pass ciphertext * priv aes priv-pass ciphertext * access-level rw
    snmp-server host * inform version v3 user *
    SNMP Profile has been bound to the appropriate Device in HPE IMC and a SNMP Credential Check is successfully.
    But still the deployment task fails, if the "Before deployment, save the device's running configuration as a startup configuration." option is enabled :-(
    Aruba-CX should do this operation via SNMP as described in:
    SNMP write: Configurations (arubanetworks.com)
    But as formerly told, HPE IMC does not...
  • 2.  RE: HPE IMC: Aruba CX, save running to startup option does not work
    Posted Dec 11, 2023 01:52 PM
    Hi R Grossman, this problem should be fixed in 710H02.
    Kind Regards
    Paola
  • 3.  RE: HPE IMC: Aruba CX, save running to startup option does not work
    Posted Dec 15, 2023 02:21 PM
    hi & thanks,
    updated and yes this problem/feature has been solved with the patch.
