Hi R Grossman, this problem should be fixed in 710H02.
Kind Regards
Paola
Original Message:
Sent: Dec 08, 2023 03:25 AM
Subject: HPE IMC: Aruba CX, save running to startup option does not work
I want to backup the running config to the startup config before deployment, but it does not work, it fails. So the complete task stop and finish unsuccessfull.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/70181009defd490bb75ee598a32cbd17.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/aa5ee6496e524db79a4e9ad98812b22f.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/e61df33f93b644de974b3421ab4be031.png)
SNMPv3 with access-level rw is configured:
snmp-server vrf default
snmp-server trap-source interface vlan8 vrf default
snmp-server response-source interface vlan8 vrf default
snmp-server vrf mgmt
snmp-server system-description LAN-Switch 24P-CX-6200F
snmp-server system-location *
snmp-server system-contact *
snmp-server snmpv3-only
snmpv3 user * auth sha auth-pass ciphertext * priv aes priv-pass ciphertext * access-level rw
snmp-server host * inform version v3 user *
SNMP Profile has been bound to the appropriate Device in HPE IMC and a SNMP Credential Check is successfully.
But still the deployment task fails, if the "Before deployment, save the device's running configuration as a startup configuration." option is enabled :-(
Aruba-CX should do this operation via SNMP as described in:
SNMP write: Configurations (arubanetworks.com)
But as formerly told, HPE IMC does not...
