Network Management
HPE IMC - Export firmwares from devices (To CSV or Excel)
  • 1.  HPE IMC - Export firmwares from devices (To CSV or Excel)
    Posted Feb 09, 2021 08:26 AM
    Hello, i have like 400 devices which i need to upgrade.
    I can get they firmware by clicking on "Resource => Device View" then i need to click on every device, one by one to check the firmware in the field "System Description" which is provided by SNMP.
    My question is : Is there any way to export all the "System Description" fields from all of my devices instead of clicking on every one, check the firmware, go back and clic a second one, etc.
    My SNMP is correcly configure because i can get the informations i need, it's just like it seems impossible to export that field from all devices at once.
    Thx for your help.
    #firmware
    #snmp
    #export
    #HPEIMC
  • 2.  RE: HPE IMC - Export firmwares from devices (To CSV or Excel)
    Posted Feb 10, 2021 05:48 AM
    You probably want to check out the Report -> Report Template List. There is a 'Device Asset Report v2' (and a concise version) that you can run, which shows you a lot of device details including the firmware the devices are running. The reports in iMC can be exported to CSV and a wide variety of other formats.
