Hi R Grossman the command itself will depend on the switch but IMC scripting will not wait for the reboot.
You can try the reboot menu in batch operation.
Kind Regards
Paola
Original Message:
Sent: Dec 08, 2023 02:48 AM
Subject: HPE IMC: How to reboot a switch via (e.g via Configuration template)
push....
anyone?
Original Message:
Sent: Nov 15, 2023 11:12 AM
I want to "boot system primary" via IMC.
But when I make a configuration template, then it does not work. I guess because the y confirmation is missing.
But when I make a second statement in the configuration script with an y, it dos even not work, furthermore now there is a error message ssh timeout..
Does anyone know how and what to type in the cli script, for making the boot system command working?
And a CX related question... Is it possible to start a job WITHOUT a schedule? Or to trigger an schedule/job instantly?
I did not find a trigger now or a start ob command :-(
Thanks an kind regards
Robert
