Network Management
HPE IMC Software Import and Update for Aruba CX
This thread has been viewed 53 times
  • 1.  HPE IMC Software Import and Update for Aruba CX
    Posted Jul 22, 2022 03:15 AM
    Hello Guys,
    We're using HPW IMC (iMC PLAT 7.3 (E0706P11)).
    Software Import to Software Library is working fine for Aruba OS (Download from Web) and Software Update is also working fine.
    But when I try to Import Software from Web for Aruba CX Switches (6100, 6200, 8325, 8360) then there always the message "no update items found".
    So I have downloaded the software files manually and imported them by file to software library.
    When I do a Deployment to a Aruba CX Switch this does not work. After rond about 30 Minutes the task for a single Device is "particially succeeded", but the new Device Software has not been uploaded to the Device.
    All I can find in the routers log is the following: "Event|4404|LOG_ERR|AMM|1/1|User manager: secondary image update failed via local copy"
    All Switches are configured with "ip source-interface all interface vlan8 [vrf MGMT-Switches]".
    For all VRF Aware Devices the VPN Instance MGMT-Switches has been set in IMC Options.
    Manually upgrading from the switch CLI is working fine, but the automated task from within HPE IMC NOT.
    Does anyone have an idea?
    Thanks and Kind Regards
    Robert
  • 2.  RE: HPE IMC Software Import and Update for Aruba CX
    MVP GURU
    Posted Jul 22, 2022 06:48 AM
    Hi Robert, TFTP and "SFTP Server" file transfer modes are supported (Configuration Backup and Restore, Software Upgrade, Compliance Check Task all support TFTP and "SFTP Server" file transfer modes). Are you using TFTP transfer mode?
  • 3.  RE: HPE IMC Software Import and Update for Aruba CX
    Posted Jul 22, 2022 07:09 AM
    Yes TFTP is the default.
    I now have installed a 3rd party scp/sftp Server on the HPE IMC and changed the transfer mode for one of the Aruba CX Switches.
    Now the Software update is working.
    Of course I have to be aware of the VSX Pairs. I guess I will create to tasks, or manually do tghe update by CLI "vsx update-software boot-bank primary"
    HPE IMC and VSF/VSX seems to not interact with each other very well.
    And the other question is, why it is not possible to get Aruba CX Software to IMC via Import from Web?
    ==> with manually iporting of the swi file the readme is missing, which was included for the web imported aruba os software images,
  • 4.  RE: HPE IMC Software Import and Update for Aruba CX
    Posted Jul 22, 2022 07:47 AM
    Well there is still one more "error" by updating Aruba Software with IMC Task.
    I always mark "Set the Current Running Software as Backup Startup Software" and it has worked fine for the Aruba OS.
    But the Aruba CX --> ... -vtysh[2660906] <ERR> Event|4404|LOG_ERR|AMM|1/1|User manager: secondary image update failed via local copy
    Before: primary and secondary image --> LL.10.09.1020
    And much more important that the secondary image is shown as the same as before, is that the software image had been corrupted. Verify Command tells about failed:
    sasw-rz-r08# sh images
    ArubaOS-CX Primary Image
    Version : LL.10.09.1040
    Date    : 2022-07-18 23:56:41 UTC
    SHA-256 : 9c7bb4983bdc7de41b3c25b454a74213b8721636965a1ec573b83202c997ed29
    ArubaOS-CX Secondary Image
    Version : LL.10.09.1010
    Date    : 2022-03-10 23:07:42 UTC
    SHA-256 : 0d1f269211262c4ef3e2c4596e8ef8d59f59e69c2070d92f1ee721b47f327f01
    Default Image : primary
    Boot Profile Timeout : 5 seconds
    Management Module 1/1 (Active)
    Active Image       : primary
    Service OS Version : LL.01.10.0001
    BIOS Version       : LL.01.0001
    sasw-rz-r08# sho images verify secondary
    Image verification failed, internal software error
    That of course is VERY DANGEROUS and really should not be!
    Edit: the verify statement is only available on the 8360 plattform, not on the 8325. So on this platform there is no way to check if the image has been corrupted by the update/copy task...
    Edit Update:
    After uploading the new image files from IMC to 8325 now the option verify can be used for show images.
    The messages for theuploaded image is valid, the untouched backup/secondary software gets the result invalid.
    In this run I do not have used the option to copy the running software to the second boot bank.
    Seems that updating by IMC enables some more options on the switch...
