Comware
HPE JG938A Switches
  • 1.  HPE JG938A Switches
    Posted Apr 07, 2022 03:47 AM
    Hi All,
    We are currently using JG938A (HPE5130EI) switches on commware and using the port as hybrid (not access/trunk - https://www.utepo.net/article/detail/251.html). The reason behind this is that with 1 uplink to the users desk we are able to connect their pc and telephone (the uplink is connected to the telephone and the telephone has a 2 port switch that is conneted to the PC). The PC VLAN and Telephone VLAN are different and the hybrid allows untagging of multiple VLANs on the same port. VLAN  assignment is done through 802.1x.
    On the new HPE switches the hybrid option is no longer available and was wondering if there is an alternative to this?
    Luke Bianco
    Luke Bianco
  • 2.  RE: HPE JG938A Switches
    Posted Apr 07, 2022 04:05 AM
    Hello Luke,
    5140 has hybrid ports feature. Which other new HPE switches do you mean?
    PS: you may check the 5140 switches.
    https://buy.hpe.com/emea_europe/en/networking/switches/fixed-port-l3-managed-ethernet-switches/5100-switch-products/hpe-flexnetwork-5140-ei-switch-series/p/1013240831
    Hope this helps!
    -Alex-
  • 3.  RE: HPE JG938A Switches
    Posted Apr 07, 2022 04:31 AM
    We currently bought 1x 3810M which does not have this feature.
    Luke Bianco
