Network Management
HPE Networking IMC Standard Software - System Requirements
  • 1.  HPE Networking IMC Standard Software - System Requirements
    Posted 19 hours ago
    I can't seem to find the latest System Requirements for running on a virtual server. Basically looking to run on a Hyper-V envirnoment with embedded database, does anyone have a link to the latest system requirement.
    Many thanks
    Paul
  • 2.  RE: HPE Networking IMC Standard Software - System Requirements
    Posted 18 hours ago
    Such information is included in the Readme/Release notes under Installation Prerequisites. Also check the documents on modules that you may install.
  • 3.  RE: HPE Networking IMC Standard Software - System Requirements
    Posted 12 hours ago
    Thanks Herman,
    I had seen these but they seemed old, but will we be ok if we go for: -
    1 x Processor
    12GB RAM
    100GB HDD
    Its only to support a small network, 20 switches.
    cheers
    Paul.
