I've got an office with 2 x OC20s configured. We've been having serious issues with random glitching on conferencing (any conferencing .. and we pretty much use them all). It's taken me a while to track it down but it appears to be the APs themselves.
If you keep a ping going from the LAN side and one from the Wi-fi side to the APs IP.. you can see every now and then some large peaks. These peaks can be up to 900ms. Once they go above 100-200ms you start to see the glitching in the conferencing software.
It's not load as I've been the only one in the office, the only one on the AP and seeing the latency from the LAN and the Wi-fi side. I've ruled out the cabling as well as the network side.
Unforetuntely the GUI is a bit simple so I'm limited on what diagnostics I can do on it.
Has anyone had similar issues at all with these APs?
#latency#OC20#conferencing
