Wired Intelligent Edge
HPE OfficeConnect 1920S
  • 1.  HPE OfficeConnect 1920S
    Posted Dec 20, 2017 11:55 AM
    Hi, i don't know if this is the correct place to ask this question...
    i have a problem with a switch HPE 1920S.
    When i want to make a backup of configuration appears an error:
    Error: File Write Failed.
    It is in the last firmware, with previous firmware happens the same.Error Backup.jpgOnly happens with Backup Configuration, other options i can do the backup.backup options.jpg
    Anyone know what might be happening?
    Thanks for all.
  • 2.  RE: HPE OfficeConnect 1920S
    Posted Dec 22, 2017 09:48 AM
    Feel free to reach out the support team, they'll help you out.
    http://h17007.www1.hpe.com/OfficeConnect/
  • 3.  RE: HPE OfficeConnect 1920S
    Posted Jan 12, 2018 03:27 PM
    This is not exactly an issue with the switch or its code. You probably don't have a backup config created yet. Change the drop down menu option to startup configuration and then try the transfer again. It should work. I lost a couple of hours on this.
