Comware
  • 1.  HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 22, 2017 05:46 PM
    I recently got a couple of HPE 1950's placed on my desk - traditionally I have worked from the CLI for switching products.
    I had not worked with these switches before, and I must say, they are quite different to what I am used to.
    For instance, the requirement to use xtd-cli-mode to then, be able to enter system-view was quite odd to me.
    My primary issue now though is, how do I reboot / reload from the CLI?
    It is clearly possible in from the Web UI, but there are no familiar commands in the CLI relating to rebooting the switch. In the user manual I have found online, there is however reference to a reboot command, which seems unavailable on my switch?
    I had also checked for the latest firmware for these switches, but couldn't find anything.
    For reference, here is my display version:
    HPE Comware Software, Version 7.1.045, Release 3113P05
    Copyright (c) 2010-2016 Hewlett Packard Enterprise Development LP
    HPE OfficeConnect 1950-24G-2SFP+-2XGT uptime is 0 weeks, 0 days, 18 hours, 41 minutes
    Last reboot reason : USER reboot
    Boot image: flash:/1950-cmw710-boot-r3113p05.bin
    Boot image version: 7.1.045, Release 3113P05
    Compiled May 25 2016 16:00:00
    System image: flash:/1950-cmw710-system-r3113p05.bin
    System image version: 7.1.045, Release 3113P05
    Slot 1:
    Uptime is 0 weeks,0 days,18 hours,41 minutes
    HPE OfficeConnect 1950-24G-2SFP+-2XGT JG960A with 1 Processor
    BOARD TYPE: 1950-24G-2SFP+-2XGT
    DRAM: 1024M bytes
    FLASH: 512M bytes
    PCB 1 Version: VER.D
    Bootrom Version: 145
    CPLD 1 Version: 001
    Release Version: HPE OfficeConnect 1950-24G-2SFP+-2XGT JG960A-3113P05
    Patch Version : None
    Reboot Cause : UserReboot
    [SubSlot 0] 24GE+2SFP-Plus+2XGT
    Any and all information would be appreciated - I am trying to document this hardware, and I am awstruck by how difficult HP has made it to manage these switches via CLI.....
    #1950
    #OfficeConnect
    #HPE
    #comware
    #Reboot
  • 2.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 22, 2017 06:05 PM
    Start here.
    Really reboot CLI command (on system-view) doesn't exist?
    P.S. HPE OfficeConnect 1950 Switch series, despite the Comware 7 under the hood, is basically different from other Comware 7 (and 5 too) series...basically because it has (or it should have) a Web Management interface that let you fully configure the device from A to Z (I doubts that: IRF for example is called "stacking" where on all other Comware based switches IRF is simply IRF, sic et simpliciter...there should be no need to hide or obfuscate)...the CLI shell should not be used (as happens/happened for lower end HPE OfficeConnect 1920 Switch series)...or, better, the idea is that user should not use the CLI at all.
  • 3.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 22, 2017 06:25 PM
    Well, I attempted to configure IRF from the WebUI, and failed.
    I configured IRF from the CLI, and it worked the first time.
    Surely there is a way to reboot these devices from the CLI?
    Anyone?
    Brad
  • 4.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 23, 2017 05:28 AM
    I think the reboot command is only available in CLI when you go out of system-view.
  • 5.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 23, 2017 05:26 PM
    I have already run xtd-cli-mode, and then following that, system-view; there is still no reboot command available.
    That is why I am posting.
    B
  • 6.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 24, 2017 03:04 AM
    That's pretty strange IMO. Once you log in with admin credential you should see these list of possible commands (with ?):
    <HPE>?
    User view commands:
      display       Display current system information
      initialize    Delete the startup configuration file and reboot system
      ipsetup       Configure an IP address for VLAN-interface 1
      password      Specify password of local user
      ping          Ping function
      poe           Power over Ethernet
      quit          Exit from current command view
      reboot        Reboot operation
      summary       Display summary information of the device
      telnet        Establish a telnet connection
      transceiver   Enable transceiver phony alarm
      undo          Cancel current setting
      upgrade       Upgrade the system boot file or the Boot ROM program
      xtd-cli-mode  Switch to extended CLI mode to display and execute all commands
                    (special authorization required)
    As you see, reboot is (or it should be) available; in extended CLI mode (xtd-cli-mode) the reboot command should be available too.
    Which software version is your switch running on?
  • 7.  RE: HPE OfficeConnect 1950-24G-2SFP+-2XGT - reboot / reload from CLI ?
    Posted Nov 26, 2017 04:50 PM
    Hi, thanks for sharing your experience.
    I did include my version in the OP.
    Brad
