Hi There,
We had a power failure two days back and the switch now seems to be not working. When I checked through console, below is what I got.
Starting......
Press Ctrl+D to access BASIC BOOT MENU
* HP 1950-48G-2SFP+-2XGT Switch BOOTROM, Version 124 *
Copyright (c) 2010-2015 Hewlett-Packard Development Company, L.P.
Creation Date : Apr 13 2015, 14:45:33
CPU Clock Speed : 400MHz
Memory Size : 1024MB
Flash Size : 512MB
CPLD Version : 001
PCB Version : Ver.D
Mac Address : 2c233ad7aa60
Press Ctrl+B to access EXTENDED BOOT MENU...0
Loading the main image files...
Loading file flash:/1950-cmw710-system-r3109p05.bin.............................
...............................Done.
Image file flash:/1950-cmw710-system-r3109p05.bin is invalid!
Loading the backup image files...
The image does not exist!
Loading images fails.
Loading the main boot and system image files...
................................Done.
Loading the backup boot and system image files...
Loading the main boot image...
Loading file flash:/1950-cmw710-boot-r3109p05.bin...........Done.
Image file flash:/1950-cmw710-boot-r3109p05.bin is self-decompressing...........
..................................Done.
System is starting...
<boot>
Prior to posing this thread, I did a bit of research and tried doing a software upgrade using this link here and returned with no success. I am still getting the same error as above. Further, when I tried doing using TFTP and FTP, this is what I'm ending up with.
EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Ctrl+C: Display Copyright
Enter your choice(0-8): 6
1. Update full BootRom
2. Update extended BootRom
3. Update basic BootRom
0. Return to boot menu
Enter your choice(0-3): 1
1. Set TFTP protocol parameters
2. Set FTP protocol parameters
3. Set XMODEM protocol parameters
Load File Name :1950-CMW710-R3115P08.ipe
:1950-CMW710-R3116.ipe
Server IP Address :10.2.7.39
Local IP Address :10.2.3.20
Subnet Mask :255.255.240.0
Gateway IP Address :0.0.0.0
Loading.........................................................................
...................................Done.
No Basic BootRom File
No extended BootRom File
A bit of a help will be highly appriceated.
#HPE#OfficeConnect#1950
