Wired Intelligent Edge
HPE Switch “Software caused connection abort”
  • 1.  HPE Switch “Software caused connection abort”
    Posted Apr 19, 2021 03:31 AM
    I have a stacked HPE 2920 switches which have two vlan-interfaces (VLANs 200 and 96):
    vlan 96
     name "mgmt"
     untagged 1/1,2/1
     tagged 1/48,Trk1-Trk5
     ip address 192.168.96.20 255.255.255.0
     ip helper-address 10.200.200.26
     exit
    vlan 200
     name "inside"
     untagged 1/2-1/36,2/2-2/36
     ip address 10.200.200.150 255.255.0.0
     exit
    Pings will be answered on both IP-Addresses. But the SSH Connetion only works on the VLAN 200. I get the following error message on the VLAN 96 IP-Address:
    Network error: Software caused connection abort
    No ACL are set on the switch.
    Have someone an idea where could be the issue?
    Thanks for your help in advance.
    #server
  • 2.  RE: HPE Switch “Software caused connection abort”
    Posted Apr 20, 2021 11:37 PM
    Can you please share 'show ip ssh' output?
    Thanks!
