Wired Intelligent Edge
HPE/Aruba 2530 with external CaptivePortal/EWA Server
  • 1.  HPE/Aruba 2530 with external CaptivePortal/EWA Server
    Posted Jun 10, 2016 04:19 AM
    Hi there,
    I have a Aruba 2530 switch with the newest release and I would like to see the external captive portal from Clearpass running for web based auth using wired ports.
    The command for the 2530 seems to be:
    aaa port-access web-based ewa-server 10.1.2.3 "/guest/login.php"
    It will end in a loop if I connect to this. Seems that those switches only support html and no php.
    While using a webserver with html, it is working fine. I would like to get this running with Clearpass Guest CaptivePortal
    Any idea how I can get this running with Clearpass, which is php?
    Regards
  • 2.  RE: HPE/Aruba 2530 with external CaptivePortal/EWA Server
    Posted Jun 10, 2016 07:54 AM
    Take a look at the ProCurve / ClearPass TechNote. The redirect URL needs to be sent back from ClearPass.
  • 3.  RE: HPE/Aruba 2530 with external CaptivePortal/EWA Server
    Posted Jun 10, 2016 08:22 AM
    The technote isn't listing external captive portal/EWA server. I only find internal captive portal with external authentication
