Comware
HSR6602 BGP conditional routing
  • 1.  HSR6602 BGP conditional routing
    Posted Mar 10, 2022 09:37 PM
    Greetings Team,
    I have a customer that wants to have routes advertised to an eBGP peer (110.145.156.57) based on the condition that the advertising router does not receive a default route from its iBGP peer (192.168.0.18).  I have built the scenario in my lab and am unable to make it work.  The Cisco version of the same behavior works fine.  Is there something wrong with my logic? - config snapshot below...
    Any help you can provide is greatly appreciated..
    BGP CONFIG
    bgp 139700
    graceful-restart
    timer keepalive 30 hold 90
    peer 110.145.156.57 as-number 1221
    peer 110.145.156.57 connect-interface Vlan-interface660
    peer 192.168.0.18 as-number 139700
    peer 192.168.0.18 connect-interface Vlan-interface108
    address-family ipv4 unicast
    filter-policy prefix-list block-NODE-1-subnet import
    aggregate 103.143.185.0 255.255.255.0 as-set detail-suppressed
    network 103.143.185.0 255.255.255.240 route-policy LOCAL_PREF_Telstra
    network 103.143.185.16 255.255.255.252 route-policy LOCAL_PREF_Telstra
    network 103.143.185.28 255.255.255.252 route-policy LOCAL_PREF_Telstra
    network 103.143.185.32 255.255.255.224 route-policy LOCAL_PREF_Telstra
    network 103.143.185.64 255.255.255.224 route-policy LOCAL_PREF_Telstra
    network 103.143.185.96 255.255.255.240 route-policy LOCAL_PREF_Telstra
    network 103.143.185.128 255.255.255.128 route-policy LOCAL_PREF_Telstra
    network 103.168.45.0 255.255.255.0 route-policy LOCAL_PREF_to-MGMT
    peer 110.145.156.57 enable
    peer 110.145.156.57 advertise-policy AS1221-out non-exist-policy AS137549-in
    peer 110.145.156.57 route-policy AS-1221-INCOMING import
    peer 192.168.0.18 enable
    peer 192.168.0.18 next-hop-local
    ROUTE POLICY CONFIG
    route-policy AS-1221-INCOMING permit node 10
    if-match as-path 1
    route-policy AS-1221-OUTGOING permit node 10
    if-match ip address acl name advertise-mgmt
    route-policy AS1221-out permit node 10
    if-match ip address prefix-list MGMT-prefix
    route-policy AS137549-in permit node 10
    if-match as-path 2
    if-match ip address prefix-list AS137549-track
    route-policy LOCAL_PREF_Telstra permit node 10
    apply local-preference 200
    route-policy LOCAL_PREF_to-MGMT permit node 10
    if-match ip address prefix-list to-AGN-W-MGMT
    apply local-preference 150
    IP PREFIX-LIST CONFIG
    ip prefix-list AS137549-track index 5 permit 0.0.0.0 0
    ip prefix-list MGMT-prefix index 5 permit 103.168.45.0 24
    ip prefix-list advertise-mgmt index 10 permit 103.168.45.0 24
    ip prefix-list advertise-prod index 10 permit 103.143.185.0 24
    ip prefix-list block-NODE-1-subnet index 5 deny 116.206.187.80 29
    ip prefix-list block-NODE-1-subnet index 10 permit 0.0.0.0 0
    ip prefix-list to-AGN-W-MGMT index 5 permit 103.168.45.0 24
    ip as-path 1 permit 1221
    ip as-path 1 permit ^$
    ip as-path 2 permit 137549
    ip as-path 2 permit ^$
    BGP ROUTING TABLE (local)
    ]show bgp routing-table ipv4
    Total number of routes: 11
    BGP local router ID is 172.16.0.1
    Status codes: * - valid, > - best, d - dampened, h - history,
    s - suppressed, S - stale, i - internal, e - external
    Origin: i - IGP, e - EGP, ? - incomplete
                Network                   NextHop             MED      LocPrf     PrefVal     Path/Ogn
    *  >e    0.0.0.0                         110.145.156.57                                  0               1221i
    *    i                                          192.168.0.18         0           100 0                        137549i  <---- this route is present hence policy route advertisement should suppress
    *  >    103.143.185.0/24        127.0.0.1                                           32768           i
    s  >     103.143.185.0/28       192.168.0.2           0             200      32768           i
    s  >     103.143.185.16/30     192.168.0.2           0             200      32768           i
    s  >     103.143.185.28/30     192.168.0.2           0             200      32768           i
    s  >     103.143.185.32/27     192.168.0.2           0             200      32768           i
    s  >     103.143.185.64/27     192.168.0.2           0            200       32768           i
    s  >     103.143.185.96/28     192.168.0.2           0             200      32768           i
    s  >     103.143.185.128/25   192.168.0.2           0             200     32768            i
    *  >     103.168.45.0/24          192.168.0.10        0             150     32768            i
    BGP ROUTING TABLE PEER  (110.145.156.57 )
    BGP table version is 43, local router ID is 3.3.3.3
    Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
    r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
    x best-external, a additional-path, c RIB-compressed,
    Origin codes: i - IGP, e - EGP, ? - incomplete
    RPKI validation codes: V valid, I invalid, N Not found
           Network                       Next Hop                   Metric      LocPrf      Weight      Path
    *>    0.0.0.0                       192.168.100.2                                                    0           37549 i
                                                0.0.0.0        0          i
    *>    103.143.185.0/24    110.145.156.58                                                  0         139700 i
    *      103.168.45.0/24       192.168.100.2                                                    0        137549 139700 i
    *>                                        110.145.156.58               0                                0         139700 i  <--- this route should be suppressed
    *>    116.206.187.80/29   192.168.100.2                                                    0         137549 139700 i
    *      158.39.0.0/24              192.168.100.2                0                                0          137549 i
    *>    0.0.0.0        0                            32768     i
    Con Stathis
