last person joined: 11 hours ago
HT80 vs non HT80
  • 1.  HT80 vs non HT80
    Posted Jan 13, 2016 12:52 AM
    what are the differnces between HT80 vs non HT80.
    Thank you
  • 2.  RE: HT80 vs non HT80
    Posted Jan 13, 2016 12:55 AM
    Where are you seeing this? It should read VHT80.
    Sent from Nine
  • 3.  RE: HT80 vs non HT80
    Posted Jan 13, 2016 04:47 AM
    I saw in another vendor cisco :)
    802.11ac Receive Sensitivity
    802.11ac (non HT80)
    ●  -86 dBm @ 6 Mbps
    ●  -76 dBm @ 54 Mbps
  • 4.  RE: HT80 vs non HT80
    Posted Jan 13, 2016 09:03 AM
    HT80 should be VHT (Very High Throughtout) 80 means 8(4 x 802.11a 20 MHz channels bond together) = 802.11ac.
    in most deployments its recommended to just disable it specially since most wireless deployments today are high density and when this is enable you end up getting only two channels available (No DFS enabled) and three (DFS enabled).
    When you disable VHT(80) that means that you could either have HT40 or HT20 .
    I recommend you read the Aruba 802.11ac VRD there's more details that will help answer some of your questions
    Sent from Outlook Mobile
  • 5.  RE: HT80 vs non HT80
    Posted Jan 14, 2016 06:20 AM
    Thank you so much
    For test purpose i did channel bonding (80Mhz).But still i am getting around 100-105 mb datt rate
    Thank you
  • 6.  RE: HT80 vs non HT80
    MVP
    Posted Jan 14, 2016 07:08 AM
    it's cisco equipement, what did you expect? :P
    A bit more serious: does the client you test with support 80MHz channels?
    ~100Mbps sounds more like a 20MHz n-client rather than anything supporting 80MHz channels.
  • 7.  RE: HT80 vs non HT80
    Posted Jan 14, 2016 08:00 AM
    You may want to post on the Cisco forums.
    Sent from Nine
  • 8.  RE: HT80 vs non HT80
    Posted Jan 14, 2016 08:32 AM
    I am just studying and comapring .
    Thank you
  • 9.  RE: HT80 vs non HT80
    Posted Jan 17, 2016 02:51 PM
    Hi
    after bonding (80 ) the dfschannel will be 4 or 3 ? .
    after bonding  52,56,60,64  , how the client address the channel,52  or 64
    Thank you
  • 10.  RE: HT80 vs non HT80
    Posted Jan 17, 2016 04:40 PM
    5 Channels with DFS : 36E (36, 40, 44, 48), 52E (52, 56, 60, 64), 100E (100,104,108,112) and 132E (132,136,140,144) and 149E (149,153,157,161)
