Hi everyone,
I'd like to disable HTTP Web-Interface on HP 1700-8, 1800-8G and 1810-8G. I just wanna allow HTTPS. How does it work?
Pourl
There is noone how has the wish to disable http ?
I don't know why nobody has answered you for the last ten months. HP appears to ignore these forums. I discovered that for the 1810-8G at lease, once you enable HTTPS you have the option to disable HTTP on that same Security->Secure Connection page.
This is a peer to peer forum, not an official HP support site. Try the HPSC:
http://www.hp.com/go/hpsc
thx 4 your reply. But I cant disable HTTP, just disable/enable https.
