https://www.arubanetworks.com/assets/alert/ARUBA-PSA-2021-007.txt no 6.4.4.8-4.2.4.19 available
  • 1.  https://www.arubanetworks.com/assets/alert/ARUBA-PSA-2021-007.txt no 6.4.4.8-4.2.4.19 available
    Posted Mar 16, 2021 06:38 AM
    Hope someone can help, in this alert we have this version has an solution to some CVE, but i cant find it to download.
    Anyone knows why?
    Resolution
    In order to address the vulnerabilities described above for the
    affected release branches, it is recommended to upgrade the software
    to the following versions (where applicable):
        - Aruba Instant 6.4.x: 6.4.4.8-4.2.4.19 and above
    vladimir Salt�o
  • 2.  RE: https://www.arubanetworks.com/assets/alert/ARUBA-PSA-2021-007.txt no 6.4.4.8-4.2.4.19 available
    Posted Mar 16, 2021 07:22 AM
    Hi Vladimir,
    Aruba Instant 6.4.4.8 is available for download in the Aruba Support Portal: https://asp.arubanetworks.com
  • 3.  RE: https://www.arubanetworks.com/assets/alert/ARUBA-PSA-2021-007.txt no 6.4.4.8-4.2.4.19 available
    Posted Mar 16, 2021 08:13 AM
    Thanks for the fast reply, but those are .18 and not the .19 that resolves the cves isnt it?
    vladimir Salt�o
