huawei captive portal templates
  • 1.  huawei captive portal templates
    Posted Oct 16, 2014 02:00 PM
    Hi, I was contacted by a company that wants to modify the login for their captive portal. They are using an access controller equipment, a huawei ac6005. After upgrading the firmware, the equipment allows for the upload of templates, using by default the portalpage.zip package template. But I can't get my hands on that package, and the people over there can't either.
    I want that package because it seems that's the only way for having an example of the structure and coding of these templates, surely they follow some specifications, but so far, I can't find anythng abuot this in the documentation. Surely must be some examples out there...
  • 2.  RE: huawei captive portal templates
    Posted Oct 28, 2014 04:31 PM
    Hi Sir,
    Did you alreay get a solution for this problem? Because I have exactly the same problem.
    tbolck
