Huawei e1750 as uplink on RAP 3
  • 1.  Huawei e1750 as uplink on RAP 3
    Posted Dec 16, 2013 07:16 AM
    Hi!
    We have used these sticks for many years without problem but then on RAP 5.
    Now when i try to use them on a RAP 3 i cant get it to work.
    These are the settings i've used before on RAP5.
    Initialization String: AT+CGDCONT=1,'IP','internet.telenor.se'
    Device Type: Option
    Dial String: ATDT*99#
    The USB disk drive on the stick have been disabled so no modeswitch should be required.
    The Modem works ok in a PC and no sim code are used.
    Controller is a 3400 with Firmware 6.2.1.3
    Anyone know how to get this working?
    Regards Jesper
    #3400
  • 2.  RE: Huawei e1750 as uplink on RAP 3
    Posted Dec 16, 2013 05:31 PM
    Is this t-Mobile or KPN?
    For T-mobile, please try:
    usb-user t-mobile
    usb-passwd tm
    usb-init AT+CGDCONT=1,"IP","internet.t-mobile"
    usb-dev 0x12D11001 usb-dial ATD*99#
    usb-tty ttyUSB0
    usb-modeswitch "-v 0x12d1 -p 0x1446 -V 0x12d1 -P 0x1001 -M 55534243123456780000000000000011060000000000000000000000000000"
    usb-type option
    For KPN:
    usb-type=option
    usb-dev=0x12d11506
    usb-init=AT+CGDCONT=1,'IP,'internet'
    usb-dial=ATDT*99# usb-modeswitch="-v 12d1 -p 1446 -M 55534243123456780000000000000011062000000100000000000000000000"
  • 3.  RE: Huawei e1750 as uplink on RAP 3
    Posted Dec 17, 2013 04:07 AM
    Thanks for the answer.
    Sadly it didn't work, though I have recognized this as a bug in  version 6.2.1.3
    I moved the AP to a controller running 6.3.1.0 and configured it. Worked perfectly.
    Moved it back to the 6.21.3 controller and it stopped working.
    So it seems I have to find a window to update the controller.
    While we are on the topic of 3G/4G does anyone know how to get a ZTE MF821D to work?
    At the moment there are no supported 3g/4g USB modems we can buy in Sweden which work with Telenor
    Would much appreciate any hint on how to get this working.
    The Huawei e1750 was our last one in stock and now we can't connect any more customers.
    /Jesper
  • 4.  RE: Huawei e1750 as uplink on RAP 3
    Posted Dec 17, 2013 08:44 AM
    These are the settings we have for the 820D.  Perhaps they are the same?
    usb_type=option (2)
    usb_dev=0x19d20167
    usb_init=AT+CGDCONT=1,'IP','online.telia.se'
    usb_tty=ttyUSB2
    usb_dial=ATD*99#
  • 5.  RE: Huawei e1750 as uplink on RAP 3
    Posted Dec 18, 2013 02:32 AM
    Sadly not.
    Even had a tac case open this spring. They really tried but coulndt get it to work.
    /Jesper
