HUAWEI E3372h and AP-203r as RAP on 8.3.0.4 Controllers
This thread has been viewed 24 times
  • 1.  HUAWEI E3372h and AP-203r as RAP on 8.3.0.4 Controllers
    Posted Jul 16, 2019 10:07 AM
    Hello!
    A customer of mine got a HUAWEI E3372h and a AP-203r which he want to terminat as RAP on a 7205 controller pair under AOS 8.3.0.4.
    Everything works fine until we want to provision the RAP with a USB-Profile.
    Environment:
    2x 7205 (Master/Backup)
    ap-203r
    AOS 8.3.0.4
    ISP: A1 (Austria)
    APN Details providet by ISP
    APN Details providet by community
    1st Problem
    As soon as a USB-Profile is tied to the RAP AP-Group, the RAP will no loger set up a IPSEC tunnel over the eth0 uplink, regardless if the LTE stick is connected to the RAP or not.
    2nd Problem
    The LTE stick will not dial up to the ISP.
    We tried two sets of configuration for the USB Profile, like recommendet in this two topics:
    1. 4G/LTE Modems Zentral Europa
    2. Konfiguracja AOS pod modem Huawei E3372h
    USB Profile 1:
    USB Device Type: huawei-cdc
    USB Device Identifier: 0x12d11f01
    USB Dial String: ATD*99#
    USB Initialization String: AT+CGDCONT=1,\"IP\",\"A1.net\"
    USB TTY device data path: N/A
    USB Profile 2:
    USB Device Identifier: 0x12d11506
    USB Dial String: N/A
    USB Initialization String: AT+CGDCONT=1,"IP","A1.net"
    USB TTY device data path: ttyUSB0
    I described the settings in a deeper detail in the german community.
    Does anybody has made some experience with the HUAWEI E3372h and a rap-203r?
    Thank you!
  • 2.  RE: HUAWEI E3372h and AP-203r as RAP on 8.3.0.4 Controllers
    Posted Jul 24, 2019 06:42 AM
    Hello!
    Update:
    It seems that the HUAWEI E3372h version dont support PPP.
    The stick must be flashed witch another firmware so that it acts like the model E3372s-153.
    Flashing a Huawei E3372h 4G LTE stick from Hilink to Stick mode
    After that, the stick should work with the following settings (ISP A1 Austria):
    Cellular configuration
    Type            Value
    4g-usb-type
    usb-type        huawei-cdc
    usb-dev         0x12d11506
    usb-tty         ttyUSB0
    usb-init        AT+CGDCONT=1,"IP","A1.net"
    usb-auth-type   PAP
    usb-user        ppp@a1plus.at
    usb-passwd      ppp
    usb-dial        ATDT*99#
    usb-modeswitch
    modem-isp
    modem-country
    I had no time to flash our stick and test the settings - will update the topic.
    Maybe someone of you had a similar expirence, I would be thankfull if you share your findings with us.
