HUAWEI E353 don´t work with RAP 3wn
  • 1.  HUAWEI E353 don´t work with RAP 3wn
    Posted Oct 09, 2013 04:52 AM
    Hello community,
    we´ve a RAP3wn and wie want to set the Uplink to 3g.
    Ok, we bought the Huawei e353 USB modem witch is on the supported list.
    The RAP comes up as an instant. I goes to Settings, and change the settings to Germany and vodafone, then I restart the RAP.
    When the RAP is up again I changed it to an Remote AP.
    But the USB Modem doesn´t work, it can´t connect to the controller.
    When I put the eth 0 interface to the LAN it works.
    But we need the 3g uplink for the remote working...
    Must I configure something?
    modeswitch?
    tty?
  • 2.  RE: HUAWEI E353 don´t work with RAP 3wn
    Posted Oct 09, 2013 08:09 AM
    This is what the ap-driver log says:
    2.4.2
    drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
    drivers/usb/serial/usb-serial.c: USB Serial Driver core
    SCSI subsystem initialized
    usb_storage: Ignoring new-style parameters in presence of obsolete ones
    Initializing USB Mass Storage driver...
    USB Mass Storage support registered.
    Port Status 1c000004
    ath-ehci ath-ehci.0: ATH EHCI
    ehci_reset Intialize USB CONTROLLER in host mode: 13
    ehci_reset Port Status 1c000000
    ath-ehci ath-ehci.0: new USB bus registered, assigned bus number 1
    ath-ehci ath-ehci.0: irq 3, io mem 0x1b000000
    ath-ehci ath-ehci.0: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
    USB Device: 0x00000000
    USB Product: ATH EHCI
    USB Manufacturer: Linux 2.6.16 ehci_hcd
    USB SerialNumber: ath-ehci.0
    usb usb1: c->desc.bMaxPower 0, udev->busmA 0
    usb usb1: configuration #1 chosen from 1 choice
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    usb 1-1: new high speed USB device using ath-ehci and address 2
    USB Device: 0x12d11446
    USB Product: HUAWEI Mobile
    USB Manufacturer: Huawei Technologies
    USB SerialNumber: <NULL>
    usb 1-1: c->desc.bMaxPower 250, udev->busmA 500
    usb 1-1: configuration #1 chosen from 1 choice
    scsi0 : SCSI emulation for USB Mass Storage devices
    usb-storage: device found at 2
    usb-storage: waiting for device to settle before scanning
    scsi1 : SCSI emulation for USB Mass Storage devices
    ip_time_handler: Got ip and packets on bond0 Started master election 4-0
    Kernel watchdog refresh ended.
      Vendor: HUAWEI    Model: Mass Storage      Rev: 2.31
      Type:   CD-ROM                             ANSI SCSI revision: 02
      Vendor: HUAWEI    Model: TF CARD Storage   Rev:
      Type:   Direct-Access                      ANSI SCSI revision: 02
     1:0:0:0: Attached scsi generic sg0 type 0
    usb-storage: device scan complete
    sr0: scsi-1 drive
    Uniform CD-ROM driver Revision: 3.20
    sr 0:0:0:0: Attached scsi CD-ROM sr0
    sr 0:0:0:0: Attached scsi generic sg1 type 5
    wlan: 0.8.4.2 (Atheros/multi-bss)
    ath_hal: module license 'Proprietary' taints kernel.
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    ath_ahb: init_ath_wmac
    Restoring Cal data from Flash
    Reading from Addr: 0xbffe100
    Anybody an idea?
  • 3.  RE: HUAWEI E353 don´t work with RAP 3wn
    Posted Nov 03, 2013 02:34 PM
    I'm having a similar problem with a Pantech UML290 and RAP 109.    The following section from the log repeats with the "address" number counting up from 2 to as high as 12.
    usb 1-1: USB disconnect, address 6
    usb 1-1: new high speed USB device using ath-ehci and address 7
    USB Device: 0x106c3718
    USB Product: PANTECH UML290
    USB Manufacturer: Pantech, Incorporated
    cdc_acm 1-1:1.0: ttyACM0: USB ACM device
    usb 1-1: USB disconnect, address 7
    usb 1-1: new high speed USB device using ath-ehci and address 8
    usb 1-1: USB disconnect, address 8
    Was there a solution to this post?
  • 4.  RE: HUAWEI E353 don´t work with RAP 3wn
    Posted Nov 04, 2013 10:37 AM
    No, my huawei usb modem don´t work yet.
    But I found something for you sharrison72.
    Maybe it helps you:
    Verizon Pantech UM150
    config t
    provision-ap
    read-bootinfo ap-name <ap name>
    usb-type acm
    usb-dev 0x106c3711
    link-priority-cellular 110
    link-priority-ethernet 100
    reprovision ap-name <ap name>
    end
    Verizon Pantech UM175
    config t
    provision-ap
    usb-type acm
    usb-dev 0x106c3714
    end
    Verizon Pantech UML290
    config t
    provision-ap
    usb-type pantech-3g
    4g-usb-type pantech-lte
    end
    Give Kodus if it helps ...
  • 5.  RE: HUAWEI E353 don´t work with RAP 3wn
    Posted Nov 04, 2013 11:40 AM
    Thanks!  Will test this afternoon.
  • 6.  RE: HUAWEI E353 don´t work with RAP 3wn
    Posted Nov 04, 2013 04:15 PM
    Thanks for the lead, but that didn't work -- it appears the command "4g-usb-type pantech-lte" is no longer supported.
