Huawei E392u-12 and RAP5
  • 1.  Huawei E392u-12 and RAP5
    Posted Oct 25, 2012 02:18 AM
    Have any of you managed to get Huawei E392u-12 4G modem to work?
    This is what I have been using and for 4G settings I have chosen "none" for now. Would like to get it to work even on 3G.
    provision-ap usb-type option
    provision-ap usb-dev 0x12d11506
    provision-ap usb-dial ATDT*99#
    provision-ap usb-init AT+CGDCONT=1,'IP','internet'
    provision-ap usb-modeswitch "-v 0x12d1 -p 0x14fe –M 55534243123456780000000000000011062000000100000000000000000000"
    provision-ap usb-dev 0x12d11505
    provision-ap usb-modeswitch "-v 0x12d1 -p 0x14db –M 55534243123456780000000000000a11062000000000000100000000000000"
    provision-ap usb-modeswitch "-v 0x12d1 -p 0x14fe –M 55534243123456780000000000000a11062000000000000100000000000000"
  • 2.  RE: Huawei E392u-12 and RAP5
    Posted Oct 25, 2012 03:21 AM
    And here is the answer to my own question. It's working.
    provision-ap master x.x.x.x
    provision-ap link-priority-cellular 20
    provision-ap link-priority-ethernet 40
    provision-ap usb-tty ttyUSB0
    provision-ap usb-modeswitch "-v 0x12d1 -p 0x1505 -V 0x12d1 -P 0x1506 -M 55534243123456780000000000000011062000000100000000000000000000"
    provision-ap usb-init AT+CGDCONT=1,"IP","internet"
    provision-ap remote-ap
    provision-ap reprovision ap-name xx:xx:xx:xx:xx
  • 3.  RE: Huawei E392u-12 and RAP5
    Posted Oct 26, 2012 08:01 AM
    New problem.
    RAP can make a connection to controller and radio comes up and stays up no problem with that.
    But client can only browse internet for about 1-2 mins after radio has come up and then all data transfers just stops.
    No matter is it split or tunnel. With modem attached to port0 it works perfectly so no problems with firewall rules.
    Any ideas?
    Btw: has anyone managed to get Huawei E353 to work?
  • 4.  RE: Huawei E392u-12 and RAP5
    Posted Mar 01, 2013 10:59 AM
    I had my HUAWEI E392u-12 with the same problem..dammed
    [Mod note: URL link removed]
  • 5.  RE: Huawei E392u-12 and RAP5
    Posted Dec 26, 2013 04:04 AM
    have you tried to update your firmware? It maybe the problem of firmware. And my version is Huawei E392u-21, it works.
