last person joined: 11 hours ago
Huawei phones not getting connected to Guest network on Aruba AP & Controller
  • 1.  Huawei phones not getting connected to Guest network on Aruba AP & Controller
    Posted Mar 05, 2019 01:00 PM
    Tested multiple Huawei brands of phones to connect to guest wifi after entering sponsor email and login email.
    and getting accepted from sponsor it giving an error
    authentication failed.
    Tested the same scenario on a couple of Huawei branded phones.
    Is it belong to DHCP fingerprint or something else?
  • 2.  RE: Huawei phones not getting connected to Guest network on Aruba AP & Controller
    Posted Aug 01, 2019 06:02 AM
    Hi
    Im having a similar issue a at a cleint.
    Huawei devices just goes back to the login screen and registering
    are you using https or http ?
    I was using http for now till we get the ssl cert sorted, so i just wanted to know if when i load the cert and use https. This will be resolved
  • 3.  RE: Huawei phones not getting connected to Guest network on Aruba AP & Controller
    Posted Aug 02, 2019 02:51 PM
    mostly Certification issu, i faced same this issue before.
