Comware
Hybrid port with RADIUS-based VLAN
  • 1.  Hybrid port with RADIUS-based VLAN
    Posted Jan 23, 2018 06:44 PM
    On a V1910 (JE009A), I'm trying to set up a hybrid port which assigns VLAN IDs to MAC addresses based on the configured RADIUS server's (freeradius, but doesn't matter I think) response.
    Example:
    1. device_1 with MAC = 0000-1111-1111 appears on the port
    2. the switch sends an auth request to the RADIUS server with username = '000011111111'
    3. the RADIUS server replies (an Access-Accept) with the proper Tunnel-* attributes which are casually used in dot1x + dynamic VLAN assignment, setting the VLAN ID for this 'user' to 10
    4. from now on the switch uses VLAN 10 for device_1
    5. device_2 with MAC = 0000-2222-0000 appears on the same port (say they're behind an unmanaged switch)
    6. the switch sends an auth request with username = '000022220000'
    7. the server replies like in step 3, only with a different VLAN ID, say 20
    8. from now on, device_2's traffic uses VLAN 20, while device_1's traffic still uses VLAN 10 (like in a standard, static hybrid port scenario)
    I'm stuck at step 4 & 8: RADIUS replies with an Access-Accept which contains the configured Tunnel-* attributes, but the port/VLAN doesn't change, here's its state:
    [switch-GigabitEthernet1/0/32]dis mac-au i g 1/0/32
    MAC address authentication is enabled.
     User name format is MAC address in lowercase, like xxxxxxxxxxxx
     Fixed username:mac
     Fixed password:not configured
             Offline detect period is 300s
             Quiet period is 60s
             Server response timeout value is 100s
             The max allowed user number is 1024 per slot
             Current user number amounts to 2
             Current domain is test
    Silent MAC User info:
             MAC Addr         From Port                    Port Index
    GigabitEthernet1/0/32 is link-up
      Authenticate success: 0, failed: 0
     Max number of on-line users is 256
      Current online user number is 2
             MAC Addr         Authenticate State           Auth Index
             0000-1111-0000   MAC_AUTHENTICATOR_CONNECT     65
             0000-2222-0000   MAC_AUTHENTICATOR_CONNECT     66
    Is such a setup technically possible?
    #Radius
    #DynamicVLAN
    #hybrid
    #JE009A
    #v1910
