Hyper-V
  • 1.  Hyper-V
    Posted Jan 11, 2013 04:03 PM
    Has anyone had any luck installed ClearPass on Hyper-V?  I don't have a Vmware environment adequate to test it in to use.
  • 2.  RE: Hyper-V
    Posted Jan 12, 2013 09:11 AM
    As far as I know it can not be run on Hyper-V.
    The supported hypervisor is VMware, however, it can be run on Xen with a little modification.
  • 3.  RE: Hyper-V
    Posted Nov 07, 2013 08:56 AM
    Hey, can you elaborate on what modifications are required to get it to run on Xen?
  • 4.  RE: Hyper-V
    Posted Nov 07, 2013 08:57 AM
    I installed AMP in Hyper-V 2012 without any modifications.
  • 5.  RE: Hyper-V
    Posted Nov 07, 2013 08:59 AM
    Sorry, I should have been more clear.
    The original post was for Clearpass, and that's what I'm interested in.
    My customer uses Citrix XEN for their Hypervisor, so I'm wondering if Clearpass will work on Xen, and if this is a supported configuration.
  • 6.  RE: Hyper-V
    Posted Nov 07, 2013 11:25 AM
    Currently Xen is not a supported VM server for clearpass. CPPM is supported on VMWare and Hyper-V is on the roadmap.
  • 7.  RE: Hyper-V
    Posted Jan 13, 2013 11:07 PM
    Hyper-V is not a currently supported virtualization host for ClearPass.
  • 8.  RE: Hyper-V
    Posted Jan 14, 2013 12:07 PM
    Neither is Airwave, but it works since version 7.5 and CentOS 6.  What version of linux does clearpass run on?
  • 9.  RE: Hyper-V
    Posted Apr 09, 2013 11:10 AM
    FYI AirWave is now officially supported on Hyper-V and is documented in the AirWave 7.6 installation guide.
    I believe they are working on verifying Hyper-V compatibility with the ClearPass VM but it isn't officially supported (yet).
  • 10.  RE: Hyper-V
    Posted Feb 05, 2014 06:11 PM
    Has anyone heard of change in policy at Aruba on running ClearPass on Hyper-V?   They were being tight-lipped, last I checked.
  • 11.  RE: Hyper-V
