I-225 and .PEM Certificate
  • 1.  I-225 and .PEM Certificate
    Posted Jan 31, 2017 05:24 AM
    I have been trying to upload a self-signed PEM certificate generated in OpenSSL, but every time I try to upload the file, I get the following error message.
    The certificate was generated using the following command on Ubuntu 16.04
    openssl req -x509 -sha256 -newkey rsa:2048 -keyout self_cert.pem -out self_cert.pem -days 1825
    as per post here: https://community.arubanetworks.com/t5/Controller-Based-WLANs/Generate-self-signed-certificate-with-OpenSSL/ta-p/275357
    The content of the certificate appears to be correct, although I am no expert in this matter.
    -----BEGIN ENCRYPTED PRIVATE KEY-----
    [ CONTENT ]
    -----END ENCRYPTED PRIVATE KEY-----
    -----BEGIN CERTIFICATE-----
    [CONTENT ]
    -----END CERTIFICATE-----
    Can anyone point me in the right direction?
    Many thanks,
    pipboy-2000
  • 2.  RE: I-225 and .PEM Certificate
    Posted Feb 01, 2017 04:14 AM
    Hi Fallout Fan, :)
    The guide you're working from is for controllers.
    Here's the Instant certificate guide.
