i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
  • 1.  i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 07:38 AM
    during conversion i am getting below eerror from logs, full log file is attached. due to this i am not able to view this AP in controller\
    show log upgrade
    ----------Download log start----------
    Executing '/aruba/bin/download_image_swarm ac-ftp://192.168.254.210/armv7ns.ari --no-proxy X-Ap-Info:CM0098113,ac:a3:1e:c2:a1:5c,AP-205'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:CM0098113,ac:a3:1e:c2:a1:5c,AP-205 -a /tmp/download_url_log ftp://sap:x@192.168.254.210/armv7ns.ari')
    --11:05:33--  ftp://sap:*password*@192.168.254.210/armv7ns.ari
               => `armv7ns.ari'
    Connecting to 192.168.254.210:21... connected.
    Logging in as sap ... Logged in!
    ==> SYST ... done.    ==> PWD ... done.
    ==> TYPE I ... done.  ==> CWD not needed.
    ==> PASV ... done.    ==> RETR armv7ns.ari ...
    No such file `armv7ns.ari'.
    Error: failed to retrieve image
    cleaning up
    done
    Attachment(s)
    txt
    aruba logs.txt   3 KB 1 version
  • 2.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 07:40 AM
    What code is your controller running?
  • 3.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 07:45 AM
    please find below
    Name: Aruba Operating System Software. Model: Aruba3200 Version: 6.3.1.2 Compiled: 2013-12-18 at 16:43:23 PST (build 41362) by p4build
  • 4.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 08:17 AM
    Hi
    To convert your IAP-205 to a campusAP, your controller needs atleast to be on version 6.4.1.
    Seems like you have a 3200, this will be problematic, as this controller does not have a large enough flash to support the newest code base.
    You will either have to switch to å newer controller or buy a upgrade kit for this 3200, making it a 3200XM
    Roar
  • 5.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 08:23 AM
    You'll need AOS 6.4 for the 205 and 215.
  • 6.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 08:30 AM
    thanks for that information, but we recently purchased this Controller and upgrade or replacing controller would not be an option for us. is there a way i can convert this IAP 205 this time atleast for next time i can purchase only normal AP's instead.
  • 7.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 08:33 AM
    No
  • 8.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 17, 2014 10:46 AM
    hi Tabrez Goilka
    if you just purchased it, you are entitled to software upgrades for 90 days per the standard s/w warranty. At any rate, for any AP2xx, you really want to be on 6.4.2.3 software.
    As Tim notes, there is no way to make this 205 talk to anything other than 6.4.x, this is detailed in the AP product matrix available at http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
    regards
    -jeff
  • 9.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 18, 2014 12:14 AM
    thank you everyone for valuable information, however can i know which APs are compatible with this controller. and whether i can somehow upgrade controller to 6.4
  • 10.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 18, 2014 03:19 AM
    Hi
    The available AP's supported by your Aruba 3200 is as follows
    As i wrote earlier, you could upgrade your Aruba 3200 controller to the latest 6.4.2.3, but as this device don't have enough flash memory, you will have to buy a upgrade kit.
    Your device as for now is unable to be upgraded to 6.4.
    Roar Fossen
  • 11.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 18, 2014 05:16 AM
    Since you´re Already on 6.3 with your controller I asume it´s and 3200XM or a 3200 with extra memory kit installed. Hence this should be fine to upgrade to 6.4.2.3 and that would be able to terminate your IAP-205 after conversion to a campus AP.
  • 12.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 18, 2014 09:36 AM
    thanks chirs,
    i was able to upgrade the OS to 6.4 and successfully converted the AP. thanks all for help.
  • 13.  RE: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
    Posted Dec 18, 2014 03:58 AM
    Before buying APs you can check which minimum software version the AP need to run in Campus mode. By going to this page: http://www.arubanetworks.com/products/access-points/ and clicking on the AP family that you ar interested in, you will be presented with info on the access points. You want to look for the "Minimum Software Version"-section. The 220 series' section looks like this:
