I like that idea. At least the signal is not bleeding through the building, But how would I get devices to disconnect at, for example, -70? My goal is to deploy a network in which -65 dBm is the worst signal within the building. So in the corners of the area that I am required to cover -65 dBm is the signal strength. Would the power setting cause the signal strength to dissipate to something so poor that a user will not be able to connect?
