I have 4 3400 controllers running 6.3 and I am unable to create a vlan pool on my slave controllers. My Master works fine but it will not allow creation on the slaves. Any ideas?
the vlan pools can be created in the master controller only , but you should map vlans ID to those vlan pools from local controllers
