I am using IAP 215, CPU Utilization for 2.4Ghz is going higher frequently?
  • 1.  I am using IAP 215, CPU Utilization for 2.4Ghz is going higher frequently?
    Posted Sep 10, 2015 08:37 AM
    Hi ,
    I am using IAP 215 and the CPU Utilization for 2.4 Ghz is going high frequently some time its rectified automatically , sometime it not. Is there any permanant solution for the same. Kindly help me.
    Sundar
  • 2.  RE: I am using IAP 215, CPU Utilization for 2.4Ghz is going higher frequently?
    Posted Sep 10, 2015 09:07 AM
    Utilization can rise just from someone doing a speed test or downloading a file. Utilization that goes high and comes back down is fine. Utilization that stays high could be a problem.
