Wired
I cannet make Ring topology on 6300m vsf. it makes only chain.
This thread has been viewed 21 times
  • 1.  I cannet make Ring topology on 6300m vsf. it makes only chain.
    Posted Dec 25, 2021 01:53 PM
    How can I make Ring topology?
    I can't make Ring topology on 6300m vsf.
    Only Chin topology  is made.
    VSF information is as below.
    ----------Cable connect-------
    Connected DAC 1/1/27 to 2/1/28
    Connected DAC 1/1/28 to 2/1/27
    ------------ config --------------
    6300# sh vsf
    MAC Address : 38:10:f0:5c:59:80
    Secondary : 2
    Topology : Chain
    Status : No Split
    Split Detection Method : None
    Mbr       Mac Address                  type                Status
    ID
    1            38:10:f0:5c:59:80          JL664A          Master
    2            38:10:f0:5c:b7:80          JL664A          Standby
    6300# sh vsf link
    VSF Member 1
                   Link         Peer              Peer
    Link       State        Member       Link           Interfaces
    1            up             0                   0                 1/1/27
    2            up             2                   2                 1/1/28
    VSF Member 2
                  Link         Peer              Peer
    1            down       0                   0                2/1/27
    2            up            1                   2                2/1/28
    6300(config)#
    6300(config)#
    6300(config)# sh vsf topology
    Stdby        Mstr
    | 2 |2==1| 1 |
    6300(config)#
    Thank you.
  • 2.  RE: I cannet make Ring topology on 6300m vsf. it makes only chain.
    MVP GURU
    Posted Dec 26, 2021 06:38 PM
    A VSF made by only two members admits only a Chain topology (Ring is not admitted with just two members only): on each VSF member you're free to aggregate physical links dedicated to logical VSF Link - respectively 1/1/27+1/1/28 on VSF Member 1 and 2/1/27+2/1/28 on VSF Member 2 - to enhance resiliency of the VSF interconnection between VSF members (sort of Link Aggregation).
    Davide Poletto
  • 3.  RE: I cannet make Ring topology on 6300m vsf. it makes only chain.
    Posted Dec 28, 2021 03:54 AM
    Thank you so much.
    I thought that even if there were two devices, making two vsf ports would make a ring.
    I'll use a lacp.
