I cannot authenticate AP105 suddenly
  • 1.  I cannot authenticate AP105 suddenly
    Posted Oct 15, 2015 08:18 PM
    Hi,All
    I want you to tell me.
    I use AP105 in AOS6.4.2.10 of Controller
    It is in condition that VerUp does AOS and passed for approximately two months.
    Now,AP105 cannot authenticate for all SSID at all suddenly occurs several times.
    It occurs in plural AP and restores when I reboot.
    I may restore naturally.
    I want to identify the cause of the obstacle, but want you to teach an ”effective command” to confirm it.
    (I assume obstacles such as the lack of memory in AP105.)
    I want to determine whether these Bug ID corresponds.
    BUGID:122542, 121740, 122374, 122539, 122914
    Regards
  • 2.  RE: I cannot authenticate AP105 suddenly
    Posted Oct 15, 2015 09:44 PM
    What kind of authentication are you doing?
  • 3.  RE: I cannot authenticate AP105 suddenly
    Posted Oct 15, 2015 11:22 PM
    Hi,Joseph
    Thank you for your reply.
    This WLAN System used MAC Authentication.
    Each PC's MAC-address Number are setting to RadiusServer.
    It sometimes occurs in plural AP, but restores when I reboot.
    I confirm that there is not the influence of the interference.
    Regards.
  • 4.  RE: I cannot authenticate AP105 suddenly
    Posted Oct 16, 2015 01:08 AM
    What Radius server?
    Are the request getting to the radius server?
    Are you rebooting the controller or the AP to fix it?
    Did you say sometimes it happens only on one AP and the other APs are working fine?
    I would do a debug of the aaa process on the controlelr and a radius debug if you can on the radius server.
  • 5.  RE: I cannot authenticate AP105 suddenly
    Posted Oct 16, 2015 01:34 AM
    ■Question1
    ■Answer2
    Because AP does not react, the certification demand does not arrive in RadiusServer.
    RadiusServer uses a appliance server made in Japan
    ■Qusestion2
    ■Ansewer2
    The controller does not reboot.
    When only AP reboots, the obstacle restores.
    ■Qusestion3
    ■Answer3
     Yes, the other APs are working fine.
    I suspect that a state before the certification becomes busy.
    Because other AP restores by reboot without influence, I suspect that AP is a problem.
    This disorder occurs in random in plural AP.
    (1-2 times of frequency for 1-2 months)
