I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
  • 1.  I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:02 AM
    Hello guys,
    This morning i wanted manage my IAP.
    But when i try to do anything appears a pop-up that says "all APs associated with this virtual controller are managed by an AirWave"
    In the configuration i can see that is configured a pubblic ip like AirWave IP but i don't have configured it.
    can you help me?
  • 2.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:11 AM
    Is this a new IAP or have you ever configured it with Airwave?  What is the serial number on this unit?
  • 3.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:17 AM
    is a new IAP and the serial number is BF0069427
    thanks in advance
  • 4.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:22 AM
    Thank you.  Not sure why that's in there.  Can you try a factory reset?  There is a small pin hole (remove the stand of the RAP3 please) and apply power while this button is pressed.  The power LED will flash rapidly.  Once done, it should return to factory defaults and broadcast the "instant" SSID.
    I do not see anything that would have automatically provisioned this so it may have had a config on it.
  • 5.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:25 AM
    OK.
    I will try.
    but i have the ip of Airwave and if i try to reach it, the login page appears... can you provide me the credentials?
    Best regards
    Andrea
  • 6.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:26 AM
    So...not sure what Airwave server you are going to.  Could you provide the IP address?  I will investigate further.
  • 7.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:32 AM
  • 8.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:34 AM
    Stay tuned
  • 9.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:41 AM
    Please try now
  • 10.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:54 AM
    Ok,
    i'm connected how can i solve my issue now?
  • 11.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 09:55 AM
    It should be resolved.  Re-login to your IAP and you should be able to change the config.
  • 12.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 10:16 AM
    HI,
    thanks now works! can you say to me what happened?
    thanks
  • 13.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 10:25 AM
    There was a misconfiguration in our Airwave server in the group this IAP was assigned to. This is because this was a demo unit for you as a partner of Aruba.
    Note for everyone else that this does NOT happen for end customers.
    Sent from my iPhone
  • 14.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    Posted Sep 11, 2014 10:20 AM
    HI,
  • 15.  RE: I cannot configure my IAP becuase is manged by AirWave, but i don't have Airwave
    If i use the same credential of the comuniti i'm logged in.
